extremely easy, not got one but helped a few mates with them because I own a brain lol. couldn't write you a good list so will leave that to someone else.
u need a constant positive run from battery through firewall , through car to boot , to amp, a negative from amp to any metal on car, a remote wire to headunit (if aftermarket) , if not to a switched positive feed, also 2 rca leads from a after market head unit to amp, if its a standard hu then u need a speaker to rca converter.
its not too hard mate, u need a power lead down one side of the car (from the battery to the amp).. this line needs to be fused. u will then need to get an earthing point.. usually some part of the body work.. and attach that to your amp using a similar size wire to your power..
then you run the RCA leads and remote anntenna (thin blue one) down the other side of your car.. i tuck all my wires into the sills.. the hardest part is finding a way through to the engine for the power lead, but im sure someone on here will be able to help u find out where it is on your car..
A Hyundai accent Mvi ( Stop the Giggleing Shes a beast : ) ) As I pap stole my 172 LOL . Thanks people does not sound to hard Just a power lead from + batt down to the boot and in to the amp and one wire from amp to earth . Got a Kenwood head unit So thats the part in not to sure about ??? & What do i do with the sub wire wise ???
yes there should either be a blue wire saying "remote lead" or something like that or on some of the kenwoods there is just a peg on the back of the headunit, which u connect a spade connector to. best to check the head units manual, should tell you in there.
