how to remove side 2.0 badges
  m-tec bmw 325 ci spo
open you door look behind where the side strips would be pop rubber bung out then push push the clip and pull the door strip to the back of the car and it should slide out i used a screw driver and leavered it off i know most pppl wont suggest it though
you need to push the clip then rap a flat head screw driver in a cloth an lever from the out side li[
RDH
Just put a flat headed screwdriver covered with a bit of tissue as not to scratch the paintwork, and then popped them off.
