HTML Code - Rotating an image help?
Andy_con
  clio 182
normally i can find the anwser on google but am struggling with this one.
i was three images to be at these angles / - \ so one at 45, one straight the other at 45
is there an hmtl code that will do this?
thanks
  Clio Mk2 Phase 1
The jQuery one would be the easiest tbh.
Load jQuery -> Load plugin -> Add events -> Done.
  182 BG
Edit the images? Aka, turn them around to 45degrees, with a transparent background, so theyre still square, just with the image you want inside the square? Sorry, struggling to describe it! Its a bodge, but itll work...
Andy_con
  clio 182
thats correct, i dont own any paint programs so cant do it.
  Clio Mk2 Phase 1
Bodge job aint worth the time, will have to fix it for different browsers.
Better off just going down the jQuery route mate. If you run in to trouble just post and I'll lend a hand if I'm at the laptop.
Andy_con
  clio 182
trouble is, is im making a news letter on mailchimp so think jquery is out the question
  Clio Mk2 Phase 1
Oh right.
Well why not just make 1 big image that holds the 3 smaller images at the angles you want and attach it as a pic in the letter?
Andy_con
  clio 182
cos sadly i dont own any paint programs but when all else fails bodge it!
Rubicon_
  L110, RS6, Westfield
To complex for HTML.
As said just make a large picture with the 3 in it, saves all the headbang code.
  Clio Mk2 Phase 1
No problem, afaik Gimp is free. Just like Photoshop. There will be many tuts online if you need them but rotating should be easy enough.
