182 Trophy
Started the car up this morning and it was running very rough. The engine management light was flashing, and the car was misfiring constantly.
I left it an hour or so and headed off to a friends garage to read the codes - by this time the misfire seems to have all but gone, but the fault code indicated a problem with the injector circuit on cyl1.
It seems to run ok now, but is a bit rough on idle.
On the way home, I stopped at a shop and upon starting it again, the EML started flashing again. Stopping and starting the car cured it, but after a few seconds it came back again. Once again I stopped and started the car but this time I drove off straight away and it stayed off.
I guess the fault code is fairly obvious, but is there a common issue? Should I really just be looking at the wiring, or is the injector a possibility, too?
Also, are there any other cars that have injectors common with the 182?
