I have a misfire on my 1.2, and replacing the coil pack hasn't solved it. I thought the next best plan of attack was to swap injectors to see if the problem follows. Do i need to remove all the inlet manifold to do this? Seems like a ballache to just swap an injector around.
I have ordered some new spark plugs too just in case.
Anything else it could be? Code read gave single cylinder misfire, and removing the ht lead from cylinder 4 has no effect on the running of the engine. Removal of all the others changes the idle.
