Karcher problem
Geddes
Car  Fiesta Mk8 ST-3
I've got a K3.99 M 14 months ago and i came to turn it on and theres nothing no power nothing. Is there a re set button on these sort of things.
When you turn it on you can hear the motor coming on there's nothing now, any ideas?
Motor could be knackered. The good news is that because of the line (3 series and above), the motor is removable and serviceable, rather than being plastic welded in.
Take to the nearest Karcher outlet and describe what's up. They will most likely charge, but it'll be far more cost effective than buying a new one.
had a smilar problem and was looking at 70 odd quid to replace the motor so said sack that and bought a niflsk one instead. when i researched it i found the range of karchers designed for home use are really quite appalling loads of people having issues with them all due to cheap build quality.
