the lambda wont cause the car to run on 3 cylinders, it may run a little poorly as it will be rich if in default.
unplug each injector while the engine is running, when one doesnt make a change to the engine sound, this is your problem cylinder. Plugs, leads are the mail culprit.. possibly injectors fault, then wiring.
Andy
KTR Sport
