Sunglasses_Ron
ClioSport Admin
One of my colleagues had just purchased a 1.5 Dci (53 plate) and he says it has a slight leak from the sunroof.
What's to the easiest fix for this? New rubbers seals?
@fairm010 i think you had this problem right?
Buy a car without a sunroof. They all do it.
Take it out, seal it up properly with silicone when it goes back in. Never ever touch it again.
I had this. 16 bolts under the headlining and the whole cassette lifts out. There is a black seal that sits under the frame on the roof. Mine had perished badly and gone in places.
A new deal from Renault is £60 ex VAT!
I sealed using a rubber draught excluder and it worked perfectly. Bolt it all back up but a bit of a bolt at a time to keep a consistent tightness over the rubber.
HTH Ron.
@Sunglasses_Ron use sikaflex 291 sealant on the frame, I had it on for 2 years, absolutely no signs of degredation and because it's flexible it also dampened the stupid creaking it made too.
http://www.ebay.co.uk/itm/SIKAFLEX-...433582?hash=item337497bd6e:g:KbsAAOSwPhdVJVUG
Do not use silicone. If you refit it and it still leaks, you'll damage the roof trying to get the frame back out.
Ring a company called "bristol sunroof centre" and they will sell you a complete seal kit and post it to you for £20.
Remove the sunroof, bin old seals, clean everything, fit new seals, fit roof back in, wallop.
2 hours work. 3 if youve never taken one out before and you're a bit dopey.
