Linux Q - keeping clamav up to date on centos.
  Trophy #267
I run a nix box which runs centos 5 as a antispam server mainly (+ a few others)
Clamav (and clamd) are installed correctly and currently happily filter out shed loads of incoming virii via postfix / amavisd / clamd.
Freshclam runs multiple times daily and keeps the defs upto date, but the main prog often needs updating.
I have been manually doing yum update clamav to update the main prog.
not 100% with nix system but would I be ok in doing that via cron ?
a daily cmd which runs a shell script or directly via crontab yum update clamd clamav and forcing Y ?
  Fiat Bravo Active TJet
Shouldn't see why not, it'd get the job done. But make sure that it logs, and mails you with any errors.
KDF
  Audi TT Stronic
What you are suggesting will work just fine.. but I wouldnt suggest it TBH.. you should really test any updated packages before you deploy them to a live server.
