Superleggera'd MK3
Alright guys, not sure if this is in the right section, move it if need be
I have an MOT coming up and its the first MOT I have had and I wondered if there are any certain checks I should personally be making prior to the test to improve chances of success? Obviously I will check oil level and washer level.
Also, I am getting the MOT done somewhere that uses a flat ramp as I cant get onto the others, will the height be an issue in terms of me passing? Its not stupidly low but I do struggle on usual ramps with the front of the car.
Any advice would be brilliant
