Lower than -60mm!
Whats the best/cheapest way of getting lower than -60mm ive got PI springs on it now that have dropped it -60mm but i want it LOWER!
Do i have to go down the coilover route or is there another option?
Its a mk3 by the way on 17"s.
to do it properly you need coilovers then you can go down to 80mm (or 110mm if you get the "special" ones)
Or you can be a pikey and cut your springs
What be these special ones then!?
Whats the cheapest set of coilovers around?
cheapest are the FKs (see k-tec website) bout £550 iirc
the special ones are FKs but i had mine made extra low!!!!
cutting springs is lethal and more than 60mm will f**k your car/handeling* up (not to mention your back)
*unless u live on a race track
