Just had a 6x4 Oval Magnex Cat Back system fitted.
Firstly it is not the same as the one shown in the Magnex Gallery
The bore of the exit pipe is now quite a bit smaller - now only 2" (50mm) diameter - with a stainless steel cone making up to the 6x4" oval
Why the change it does not look anywhere near as good as the one in the gallery
It is quite noisy and would become annoying on a long run - Maybe they are in colusion with an ICE manufacturer since you need to crank the audio up a couple of notches ...
