clio rs 182
yesterday my clio182 was running sweet,I parked up and about an hour later went for take away and the car had decided to misfire & sometimes just run on 3 pots.
Low rpm it misses & hesitates quiet bad but wind revs up it pulls ok but has misfire still. I removed & refitted ht leads off coil & it ran fine,then after a while ran it again and was playing up again. I unplugged No2 injector as scanner gave p0302 code and once unplugged the engine made no change so I assumed Mo2 injector isn't working? Or could it be plugs/leads are knackered & simply not firing No2 cylinder up..
Any feedback would be great,thanks
