mk1 Octavia VRS
History of events as follows:
1. Drove to work this morning, occasional stuttering/hesitation/misfire particularly below 3000rpm when accelerating on part throttle.
2. Seemed to go down to three cylinders but I managed to limp it to work. Engine management light flashed for a bit.
3. No faults showing when doing this.
4. Fitted new coil pack from GSF during my lunch break. Would have fitted ignition leads too but ECP seem to have given me ones for an F7R engine, not F4R.
5. Car turns over but won't start.
6. Checked plugs connected to the right terminals on the coil pack, they were.
7. Re-fitted old coil pack.
8. Car turns over but won't start. Sounds like it is trying to a little though!
The replaced the spark plugs on the service before last using the correct NGK plugs. There was no oil/water down with the spark plugs. I'm sure I have clicked the ignition leads down onto the spark plugs correctly as I've done that before when I changed the spark plugs and on other cars with no issues. Fairly sure the TDC sensor is OK as I checked it before and it was clean. Car is low on fuel (light not on yet) but I always put super unleaded in it.
Really bad time for this to happen as I'm supposed to be going to Donington tomorrow!
Just tried Wests Renault and they don't have coil packs/leads in stock today so looking like I might have to cancel the trackday and get AA recovery home so I'm not in such a rush to fix it.
