Misfiring Clio 1.2 16v 02 plate
  Renault Clio
Hi,
I have a Clio 1.2 16v 02 plate and it's started misfiring I have changed swapped the spark plugs round to make sure it wasn't a faulty spark plug and fitted a new coil pack and the problem is still happening
If anybody could help it would be much appreciated
  renault clio 1.4 16v
could be a number of things mate, if possible get a code reader and have a look at the live data and trouble codes... if you know which cylinder is misfiring then try swap the injectors around and see if the missfire follows, can also be a air leak into the manifold or a dodgey map sensor, lambda sensors rarely cause a constant missfire... they just mess up fuelling when they go... although rare... could also be a mechanical problem like a sticky valve...
