Williams 2, 182 cup
The girlfriends mk2 1.6 16v is not running properly help please.
So far I have hooked up a diagnosis computer which states a missfire on cylinder 3.
Have changed the spark plugs, checked the wires are clipped on to the fuel injectors and have done a compression test on cylinder 2 and 3 showing no issues.
Removing the wire to coil packs on cylinder 2 or 3 while the engine is running makes it run even rougher. If the wire is removed from 1 or 4 the engine cuts out.
What do I do next? What could be wrong?
