More Paint Help
  Clio GT 59
I know there are plenty of similiar threads to this about the forums but nothing I can find really answers my question. I'm looking at getting some exterior door handles for a colour coding jobbie they will come painted silver however and I'm looking to paint them nautical blue. Just wonder if I can spray straight on top of the silver or if it's a case of sanding down? If so what paper will I need? Hope someone can help.
Cheers,
Ollie
MRBILLYUK
  FF Jeden Osiem Dwa
A quick wet sand with 800 grit wet and dry for the new paint to key to should be fine . Then a few coats of colour and 3 coats of lacquer . You could primer it , but as long as you only lightly wet sand you shouldn't need to .
  Chocolate Bar™
should be ok, but just make sure you've got a good surface before you start spraying.
  Clio GT 59
Thanks for the help evry1! lost the bloody things in ebay bidding anyway went for 52 quid the pair... someone really wanted sum silver ones! anyone know where I can go about getting a pair of exterior mk2 ph2 handles?
