My Install Progress Pics
  Cupra K1 & Clio 200
Dont u think that the boxes either side of the sub are a waste of space? looks like theyre empty...
i was gonna put em flat against the side but the amount of room left it wasnt worth. so i made like that on an angel its a good place stuffin the wires n stuff.
its ok mines the 800 4 channel i thought you would of been able to bridge it to 800 but you cant can only bridge to 400 so i cant crank it up too much because it cuts its self out and goes onto a protection mode.
gotta get another one theres a 600 2 channel and 1600 2 channel not sure if theres one in between.
personally i would have mounted the amp the other way side ways down the slope so you can read the graphicxs on the amp, and keep it symetrical with another future amp on the other side. Bit too angular for mee, not smooth enough.
why not just make a custom enclosure for the sub and mount the amps in front under a windowd false sloor. Soz dont mean to be harsh just ive been working on my install for three days now non stop and like attention to detail.
why does it go into protection mode?
i got a 1600 watt 4 channel which is bridgeable but i might jus run both components and 2 subs off it and see if the subs are ok with that if not ill av to bridge it and run the components off the headunit
because its being overloaded! im sending to much power through it and it doesnt like it so it turns its self off. but i have rewired my car with 4 gauge now and also a powercap so will see if that makes any difference if not. i will get 600 2 channel and see if that will work. i looked at the 1500w but its too big and wont fit were i wont it to.
