Clio 182 Track Car
Hello all,
When I've used the brakes a few times the car starts pulling to the left under braking. That's the short story, I'll now elaborate.
I bought a road legal track car last October. The guy who stripped it out removed the yaw sensor which meant the traction control light was continuously on but otherwise it didn't cause any problems. I did a trackday at Bedford and the brakes were working as you would expect, although there was a lot of brake fade so I bought some CL RC6 pads and Brembo HC discs. I then did another trackday at Bedford. The brakes were amazing. At lunch I changed the damper settings on my Spax RSX coilovers from medium to hard but when I went back out on track the car started pulling to the left under braking. I finished the afternoon session without incident, although I nearly took out cones in the braking areas a few times and I must have been close to spinning it.
When I take the car out for a drive on the roads it brakes in a straight line for the first few hard presses of the pedal, then it starts pulling to the left when I brake.
I put new pads in thinking that one side may be glazed but that made no difference.
I put new discs on thinking that one side may be glazed but that made no difference.
I had the wheel alignment done but was told that the setting were already good.
I replaced the rubber brake hoses with braided ones but that made no difference.
I replaced the brake fluid with racing blue but that made no difference.
I swapped the front suspension units over side to side to see if it started pulling the other way but it didn't.
I bought a new caliper for the offside front but that made no difference.
I took it to a local garage for them to check all of the suspension mounts but they couldn't find any play.
I took it to a Clio specialist who checked the ABS system and he gave it the all clear.
I took the ABS fuse out to disable the system but that made no difference (other than to cover both lanes of the dual carriageway with Uniroyal smoke).
I replaced the steering wheel angle sensor but that made no difference.
I've got the car booked it to have a yaw sensor fitted so that the traction control will be operational. I don't expect this to fix the problem as it didn't have a yaw sensor when I bought the car and it has braked in a straight line for one and a half trackdays.
Can anyone suggest what to look at next ? Are there valves in the abs pump that could be sticking ?
Any advice much appreciated.
Mark.
Mark.
