Fitting is easy, like loony said timing is hard BUT, depending on the profile you are going for its quite safe to fit the new cams using the std pulleys and jsut make a timing reference mark using tipex etc before you take them out.
Then you can just put the new ones in with the marking lined up so long as you dont move the crank and the new cams have locating keys. Drive to a place that can mroe accurately set the timing up....or you could just swing the cam either way a few deg till you feel its at its best.
If you shaft the timing and get it all wrong, youll bounce valves off pistons during startup and wrecj your pistons, bores, cylinder head and valves.
Alternatively, if you dont check running cleanrances (roughly 0.100-0.150") then you could clip a piston at high rpm.
If your tappets are worn and scored/damaged them you will instantly ruin your new cams when fitting......so check them first.
