No range on trip computer , is this normal ?
  Clio 172
My range doesn't work on my trip computer 172 ph2 , I have had a couple and they had the same problem , is it just reliable renault or is it a sensor or something ?
  Clio 172
Mine does it with a full tank , so did my other car , so did my megane too , I know it should go blank when fuel light comes on , but my range has never worked on any renault
Reset needed. Press the button on the end of the stalk and then turn the ignition on. Whilst holding the button in press the reset button on the clocks and let them do their test cycle.
Should sort the problem.
  172 cup (again)
I had this when my battery was about to pack in - changed the battery and did the reset as detailed above and it works fine now
