Number plates
Whats the best thing to use to prise the existing number plates of my car and what do people use to stick/glue the new number plates on with?
Any help would be much appricated.
Thanks in advance
  Ford Fiesta
use "sellotape" double sided roll. what are your current ones mounted with?
  Turbo'd MX-5 MK4
if they are stuck on, in the past all I have done is pull them off, best to buy the proper licence plate stickers (thinner size) from Halfords.
  Mk2 172 (Silver)
i used a hairdryer to heat the old sticky pads up and pulled the old plates off, then used white spirit to get rid of all the sticky residue.
the new plates were stuck on by the same sticky pads that came with the new plates, or you can get the same things from halfords.
  133/225/CLS AMG
I had a right job getting my old plates off the dealer had used 6 sticky strips per plate. Ended up stood there with a hair dryer which softened them enought to peel them off. You can then just roll off the excess with your finger.
The Halfords sticky strip are pretty good, just use three per plate and they are solid.
Thanks in advance
If your car is anything like mine the original plates put on by the dealer will be riveted on with 2 rivets.
I had to drill mine out and then put the new ones on with body trim tape.
Nafoff
you could use body trim tape etc yeah
just fitted my new ones and used large velcro, basically the velcro covers the whole of the back of the plate and they are solid, you can also change them for shows etc.
speak to a local cobblers
