number plates
GR7
  Shiny red R32
Wongy
There might be little coloured plastic caps covering the screw heads, with little hinges, which you can lift up with a knife or pointed thing revealing the screw.
Maybe your garage stuck them on with sticky pads, in which case ignore the above!
just had a look... the front are screwed on...simple...but back ones are rivoted on...will need to drill them off i think
GR7
  Shiny red R32
Fancy using rivets these days when owners might want to remove them to put personal plates on!
Why are you taking them off Wongy? (If I may be so nosey)!
  Trophy
In my case i just rip the numberplates off!!
Cos i instructed them not to fit the plates to the car so that i could use velccro, so much neater and easier to remove if needed.
Mat.
