Hello guys!
I strongly suggest everyone buys a OBD chip for their cars! Soo flipping useful! picture of what I see on my nexus android pad below (caution, iTunes don't have any apps that work with OBD Bluetooth chips)
Just proved the effectiveness of my cold air feed with a lower vaccum pressure at full revs and 5degree celcius intake temp drop! -You can also check and remove error codes!
Quick question, the MAF (Mass air flow) sensor has a reading of zero, I assume all clio 172/182's have these sensors?? -but then again I suppose the ECU could calculate this from the vacuum/baro pressures and temp..
Apologies for the reflection of my totally interested girlfriend.
As you can see the MAF reads 0. I'm going to try a few other apps android offer to see if the missing sensors work. The engine was quite cold which is why the lambda sensors are blank.
Future plans: Turbo or NOS, oil pressure sensor.
