Own Service
  Renault Clio Dynamique
I've had the car for 1 year and i've done 15000 miles.
How would i go about doing a service on a 1.2 as i've had a look in the guides section but thats only for 1*2s.
What will i need to buy and where is it based in the engine?
  BG 182 FF
If you are looking the do the oil, oil filter. Get the parts from renault not to pricey, make sure you get a sump nut and washer just in case the old one is knackered.
Tool wise you will need a 8mm drain key with a socket wrench, some sort of container for the oil to go in, oil filter wrench and the oil. Make sort you rub some oil on the rubber part of the filter before you put it back on aswell
