Renault Clio Ph1 172
Hi lads
I've got a misfire on my PH1 172. I done a trackday at Lydden Hill back in September and the car was fine all day. It wasn't until it had sat while I watched the last few sessions the problem arose. I started it up to drive home and noticed the misfire. Since getting it home I've changed the injectors, plugs, leads and coil pack, none of which have solved the issue. Ive also discovered that when I disconnect the injector on the far right as you look at the rail it makes no difference to the idle, where as all the other 3 it does. I've checked all the wiring to that plug and it's fine.. Anyone experienced anything like this or can suggest what to try next?
Cheers, Tommy
Cheers, Tommy
