plastic polish?
  80MPG BEEZA
buying some 4" spot pads for when my pc arrives and they said i can use a plastic polish to do my headlights, whats the best polish to use to do my headlights?
  106 GTi
I was using S100 Plastic polish on mine, just used Menzerna Final Finish (PO85RD) this time round.
  80MPG BEEZA
so its safe to use a normal polish like srp? or pb ssr2 or ssr1? jst thinking i'll do my headlight while im on
  106 GTi
SRP and SSR 1 will be fine, I have never used SSR 2 on them though so can't say either way.
  80MPG BEEZA
ahh cheers rich :)
also i've just bought all the 4" spot pads for my porter cable and the 4" backing plate i dont need to change the weight on the porter cable do i? i do you know if it comes with the weight as i havent found one on the net
  80MPG BEEZA
ahh thats alright then i was starting to worry id have bought the pads and wouldnt be able to use them, you wreckon it would be possible to pc my wheels? as their like painted gloss black?
  106 GTi
Would probably be a pain, I pc'd the spokes of a 182 wheel to correct some defects and it was sort of possible. Unfortunately the lacquer was very thin and I ended up going through trying to correct the scratch.
  80MPG BEEZA
i was thinking it might be a bit of a mare but even if i can polish them abit as their usually just wiped with a sponge then a coat of wheel wax, i'll have to see how the 4" spot pad does and go carefull so i dont burn through
managaed to clean up my exhuast yesterday after fitting my new bumper the ag intensive bug and tar remover seems to work really well as i had tons of tar stuck all over my zorst
