PROSPARK DOUBLE SILICONE IGNITION LEADS
  Clio 172 Cup, Eunos
Wouldnt have thought so - just a lot more quality to the materials used, like if u upgrade phono leads on your hifi, u can get the crappy black standard ones with it, or u can upgrade them....
Would have thought the plugs just make it run more efficiently..
KDF
  Audi TT Stronic
What do you expect from a set of ignition leads, you cant expect miracles.
If anything cold starting would be slightly better, and thats it. But they would probably look quite trick under the bonnet.
  Nissan R35 GT-R
Performance leads and plugs make no difference whatsoever to performance or power. All you gain is reliability as the plugs/leads are likely to last longer.
Some people have experienced gains with fitting new plugs, but this is because the engine has been extensivley modified and requires a hotter/colder running plug from the standard one. This to me is not a real gain, as claiming back LOST power from a plug that is WRONG for the engine is not really a gain.
Audio leads however, yea they make a difference. :)
