Removal of foglights, how?
len_beach
  E92 M3,172 track car
A quick run through would be great guys.
Is it easy to remove the glass lens as the insides of mine could do with some TLC after a meeting with a big ouddle last year.
  Clio MkII 172 K reg
to remove fog lights you need to remove the wheel arch and the you will see the horn + fog light on left side and same on right. I'm not tried to remove the lens from them.
Lior
  Clio Dci100 Dynamique
i beleive you hav to take the front bumper off, bits of a pain that one cos mines smashed on the passenger side. Reno sed they'd do it for £100 or so tho so i spose thats not too bad
Christopher
  Z4M
rubbish advice so far!
just gently remove the plastic cover surrounding the light
remove 3no torx screws from the housing
pull the light out and remove the block connector from the rear.
the glass is bonded to the plastic reflector though, so you'll have a job cleaning the inside!
ChrisR
People seem to be giving advice for the ph2 models :)
As above, it's 3 torx screws to remove the unit + the surround. Then if you want to take the surround off it's held on by three nuts.
  CB600FS
Sealed unit you can't take the glass off as Christopher said. Best bets either leave them on a radiator all night, and go round sealing it with clear silicone anywhere water can get in, or leave them on all night, and do the same in the morning.
