hi how do i remove the front bumper?
Has RS 182 - Black Gold Jun 7, 2006 #2 Quite Easy 1) Jack up front end and pref. place on axel stands 2) Remove 2 x clips at top of grill (push down and fall out jobs) 3) Remove water seal in same place 4) Under car holding under tray 2 bolts 5) Each side of car (arch liners) small recess, undo and u will see bumper held onto wings by the same bolts as under the car 6) Just by fog lamp remove large push clips 7) Same bit of under tray indo torx screw 8) Pull out bumper from wings - carefull u dont scratch wings (get someone to help you) 9) Lean bumper forwards and undo fog lamp connector on passanger side (only need to undo that one) Bumper should now be completely free from the car - the odd clip or so may need undoing.
Has RS 182 - Black Gold Jun 7, 2006 #4 Dave3141 said: No need to jack up, I didnt. Click to expand... True, but its much easier to get to stuff under the car and in wheel arch. (forget mines lowered hehe)
D DaveJwxm Astra SRi T Jun 7, 2006 #5 ' 2) Remove 2 x clips at top of grill (push down and fall out jobs) is these the ones that hold the grill by the bonnet in to place?
LegoHead R35 GTR Jun 7, 2006 #6 mine too, I only had to remove two screws though, as I had no arch liners or undertray at the time.
Has RS 182 - Black Gold Jun 7, 2006 #7 wxmlad said: ' 2) Remove 2 x clips at top of grill (push down and fall out jobs) is these the ones that hold the grill by the bonnet in to place? Click to expand... Yup thats them! You push them in the middle then you can lift them out easy enough. (the pin holds it in place)
