Removing the aux belt
This is on a 182 FF.
I've removed bumper and slam panel. I can see the tensioner. It has a torx type bolt at the top and bottom and a square hole at the bottom next to the bottom torx bolt.
Which one of these releases the tension?
Can I just remove one of the torx bolts and get it off that way?
  Megane dci 130
You can just remove the top torx bolt to let the tention go, then lever the fooker back down and get the bolt in.
But the proper way is to get a 3/8 square drive in the square and pull it towards the front of the car (IIRC)!
Hope this helps.
