RS tuner info
Gaz_
  Extreme mode
Just awaiting for the unlock code from Fastchip.
Couple of Q's before i fry my ecu :eek:
Seems pretty straightforward, just reading through, it says anti virus needs turning off on my laptop. Has anybody actually done this? Any other things i should look out for? I see a charger should be hooked up to the battery also?
Gaz
  Fiesta ST3
Gaz
always good practice to shut down anti virus whilst flashing, as it has a live scan it may cause some issues,
also if possible get a charger on, if not then after you make a backup of your ECU, i would go for a drive to get the battery charged again as the backup and write takes 25-30mins each
Gaz_
  Extreme mode
Yeah charger is no problem, i'll have a fiddle this weekend lol. Await my car wont start threads lol
WHats the crack with the downloads? I see he keeps tweeking them, are there different downloads for different mods or something? (not looked at this yet, so that might sound proper spack)
  Fiesta ST3
it depends what version software and cal you have already on your ecu
once you connect up post the software versions from the main screen of the software and il try let you know which files to use.
performance cals are 5 euros each.
Gaz_
  Extreme mode
Manufacturer: 001 (Seimens Sirus 34)
Part Number: 8200313105
Program number: 00E5
Hardware version: 8200057311
Software version: 6500
Calibration version: 5E04
Diagnose version: 08
Vin no VF1CB1NDF27608206
So me being a total noob at this, would i be looking at this download? If not what should i be looking at lol. Will this help raise the idle of mine as its quite low tbh!
http://www.fastchip.nl/Clio-2/cal_6500_5404_RON98/Detailed-product-flyer.html
Gaz_
  Extreme mode
coolio. So, turn off anti virus, save original ecu on a file, then bish bash bosh, download that new one? How longs it roughly take?
  Fiesta ST3
Read ECU takes about 25mins roughly, do this first
then as you are using the latest ecu file already, go straight to write cal and choose the file you linked to above, this takes 2mins.
then all done.
Gaz_
  Extreme mode
Mint! Next job, how the f**k do i turn off my AVG lol, that'll be tomorrow nights job
Gaz_
  Extreme mode
Fine mate! Idles better and does pick up better below 5k. Only really wanted it to sort the idle issue, just seemed a little low (well lower than my previous 172/182)
Coupled with decat and inlets, it all helps i suppose :)
