Eddd sent me this - I translated it into English for those who are interested!
Engine of series
Screwed circuit gasoline with pipings aviation and connections
Specific case management
Line exhaust with catalyst
Unit supports engine and limps speeds renforçés
Disc clutch metal sintered
Limp of viteses with direct-drive dog clutches and autobloquant(couple 11x52 or 11x56) Transmissions specific
Reinforced cradle Arms inferieurs AV with silent block hard
Pins and nuts of wheels specific
Front suspensions and AR OHLINS with bottles and springs groups N Plates AV and AR rally Axle renforçé AR Holds reglage parallelism and set
Steering wheel SPARCO Ring direction in ertalon
Brake system with limiting device reglable and hydraulic hand brake
Articulation of gear shift lever to play reduit
Hull renforçée with arch of security in conformity with the standards TRUSTED 2003 Carenage aluminum under cradle Fasteners caps AV and AR
Together leve panes mechanic
CLIO RS RAGNOTTI
Groups N CONVEY ASSEMBLY NOT IMMATRICULEE
Engine of series
Line exhaust with catalyst (in conformity TRUSTED)
forged Disc clutch metal sintered Limp of viteses with direct-drive dog clutches and autobloquant(couple 11x52 or 11x56)
Plates AV and AR rally Axle nforcé
renforçé AR Holds
reglage parallelism and set Steering wheel SPARCO Ring direction in ertalon
Articulation of gear shift lever to play reduit Hull renforçée with arch of security in conformity with the standards TRUSTED 2003 rcée with arch of security in conformity with the standards TRUSTED 2003 Carenage aluminum under cradle Fasteners caps AV and AR Together leve panes mecanic CLIO RS RAGNOTTI
Groups N CONVEY ASSEMBLY NOT IMMATRICULEE (Continuation)
Harness competition Bacquets SPARCO "evo" Seat stands aluminum Kit extintor with order interieure and exterieure Manual extinguisher Tires of series
SELLING PRICE: 31 800 euro HT IN THE SAME TECHNICAL STANDARD BUT WITH A SUSPENSION BILSTEIN WITHOUT REGLAGE SELLING PRICE: 29 900 euro HT OPTIONS (not included/understood in the definitions above) 6000072690 Slope of headlights (lamps with iodine) 356.52 euro HT 6000072648 Slope of headlights (lamps with decharge) 1519.94 euro HT 6000072692 Collection supports crawls of headlights with kneecaps 142.98 euro HT 6000072647 Trap door of roof 371.83 euro HT Engine preparation with replacement camshaft of exhaust (SIEMENS Management and motorized butterfly) to consult Us Kits CLIO RS RAGNOTTI groups N COMPLETE KIT WITH SUSPENSION REGLABLE OHLINS and MULTIPOINT HULL RENFORCEE 6000072696 euro HT SUSPENSION BILSTEIN without reglage and MULTIPOINT HULL RENFORCEE 6000072697 euro HT COMPLETE KIT WITH SUSPENSION REGLABLE OHLINS WITHOUT HULL 6000072698 euro HT COMPLETE KIT WITH SUSPENSION BILSTEIN without reglage WITHOUT HULL 6000072699 euro HT KIT SUPPORTS ENGINE and LIMPS SPEEDS 6000072694 726.38 euro HT KIT CIRCUIT BRAKING with HYDRAULIC HAND BRAKE 6000072691 1442.55 euro HT MULTIPOINT KIT ARCH to weld and REINFORCEMENTS of CASE WITH SUPPORTS OF SIEGES 6000072684 euro HT KIT LINE EXHAUST without catalyst 6000072682 euro HT KIT CIRCUIT GASOLINE with screwed connections 6000072553 euro HT You will find the detail of all the parts and the prices in Documentation CLIO RS (edition April 2003) which gathers the three Poured phase 1, phase 2 and RAGNOTTI groups N classifies 3 Reference for the subscription: 77 11 129 406 22,87 Euro Including all taxes
