Rstuner. Airbag reset
Does it do this without subscribing?
Its for a clio 182.
I trial fitted an aftermarket wheel and have now refitted the std one.
Tia.
Mbeau
  Clio 172
Its for a clio 182.
Tia.
If the standard wheel was refitted correctly the airbag light should just go off.
If the rs tuner you are using has the airbag module then you should be able to access the airbag ECU, check what is causing the light to come on and either reset it or remove it.
To reset the light whatever is causing it will need to be fixed first. Hopefully that makes sense!!
