Get out of the car, walk away (run even)
Its about to expode!
Oh chill out! Where did you get that code from? Rs tuner, obdi?Thanks for a helpful responce Ben, I thought with your experience (from reading your many threads) you would have a more constructive answer.
Panda, thanks for that mate I will look into that.
is the car runnin ok ?
cud prob be just cus of ya decat
Also when really pressing on, on a good run it seems to loose power but at the same time the exhaust note goes really quiet so f**k knows what thats about!!
also if post cat is plugged in then it will be reading as though the cat isnt working. Try pluging the hole and tying the sensor up under the car so its reading fresh air.
Just out of interest in theory by doin that wudnt that make the car run rich ?
The sensor that came from the cat has been screwed back in as the decat had a hole for it????
I thought you are meant to blank that hole? Then wrap up the sensor and cable tie it somewhere safe (still connected)? The readings it is expecting will be for when a CAT was there, if you haven't got one the readings will be way out and will be causing the error. Well that is how I see it (I am no expert)![]()
why would u have to blank it when all decat pipes (yozza/milltek/ktr) come with holes for the sensors ?
Hmm ok Ill try blanking that then!! Two questions though!!!
1) why do decat pipes have the hole in the 1st place for the sensor if you are meant to blank it??
f**k knows
2) What should I blank it with?
Spark plug fits iirc
new 1st lambda + put the cat back on IMO
ps on a side not kev when is that RR day @rstuning? want to have a new catg back on for then![]()
you got that weird flat spot with the decat kev?
Just a thought....
did some research into this recently and I think i remember reading somewhere that some ECUs are able to r****d ignition to generate hotter EGTs and heat the cat up if it reads that emissions are too dirty.
Meaning if you leave your 2nd lambda in (with decat) the ECU would r****d ignition to try and heat a cat that isnt there.
Is this true?
Just googled, people reckon that its the 1st one that alters the AFR. The 2nd just tells the ECU if the cat is f**ked or not???
This is what I said mate!!!
I think you potentially have a f**ked precat which is causing fueling issues and having the post cat one plugged in is causing the error meesage.
EDIT: or if what MarkOne says is right then its all down the post cat one being plugged in, so try removing that first.
any luck sweetie?
Aye :dapprove:
Lambda out, hole plugged!...........
Engine mgmt light on along with the "check emissions" msg and spanner![]()
Will that error go away on its own though or does it need to be reset?
