F4R'd ITB'd '92 cup racer
couple of questions for anyone in the know, basically at the weekend i got the F4R fired up in the mk1 shell, it had been sat for around 8 months since last being run, i left it idling for 5 to 10 mins as it was running a bit lumpy at first, eventually it settled down.
but....
my oil temp didnt move from 20 deg at all, and yet i could feel the mocal cooler getting hot, hotter than 20 degress i'd say!
also had a coolant issue, ie that when idling it would raise the level in the expansion tank, eventually overflowing, is that just down to an air lock? i tried to run it long enough for the fan to kick in (have it set at 70 degrees) but the water temp guage didnt budge off 18 degrees :S
i have the oil temp sender in the sandwich plate, and the water temp sender in the top rad hose, any ideas why the temps stayed the same?
but....
