A coax splitter will not work just give you 2 x Coax of what you already have not 2 seperate feeds needed for SKY+
quote]
errm, as said above it will work only if you want to just record programmes rather then watch one at the same time as recording another.
and this splitter will do may need to cap the ends of your cables tho.
http://www.keene.co.uk/electronics/multi.php?mycode=KA121
If you dont wanan re cap your ends then use this splitter.
http://www.saverstore.com/productinfo/product.aspx?product_id=20003610&pid=9&tid=5
Sorry I was replying to the thread in genreal
You however still will need to upgrade your Sky package to Sky+ to allow recording as far as I am aware putting in a SKY sub card in a SKY+ box for viewing premium channels will require matching your card to the serial on your box. (calling SKY)
Sky wont as far as I aware allow you to record onto the box without the SKY+ sub so you may match the card to the box but it wont record without the extra SKY+ Sub anyway.
Then you are still stuck with the fact you have 1 x Coax feed which is fine if you want to use the SKY+ as a recording unit only. But then you may as well get a DVD recorder with HDD and not buy the extra SKY+ box and pay for the Sky+ sub
But if you want to watch TV and record you need a dual LNB and another coax feed. All the splitter would do is give you 2 of the same feed you have anyway but no good for SKY systems you woudl use this for Digital TV feeds say you had 1 arieal but you wated to pump video to 2 TV's. But you dont even need that as the SKY box has a Coax output anyway if you wanted the same image on another screen
So not sure what the splitter will do
