Clio 182
I've put a 182 engine on a 172 installation (so the engine is running with the 172 ECU). On 172 I found the speed sensor on the gearbox, but as I've seen, the 182 takes that information from ABS. How can I make the speedometer work? I've heard something about taking a wire from ABS computer to the computer inside the car.
I had to use the 172 ECU because the car I'm driving doesn't support the CAN-installation my destroyed 182 had.
