Scenic 1.6 16v K4M
Hi guys
I have a problem with my Megane Scenic 1.6 16 v 2005 mod, manual transmission, The speedometer doesn't work. My transmission doesn't use speed sensor, It takes the signal from the ABS.
The diagnosis does not recognize the Abs system.
I did this things and the problem persists:
- I changed the ABS sensors ( 4 sensors ).
- I changed the ABS module.
- I tested with my multimeter all voltages and currents in the wire connector of the ABS module. ( all voltages and currents are working well).
- i tested the cluster in other car and works fine.
I don't know how to do....
I was thinking about install a sensor in the gearbox and get directly the signal to the cluster ( pin 23 grey connector). what people think about this?
Thanks, Regards...
Thanks, Regards...
