spring compressors
Do I need to use spring compressors when converting to coilovers? I wasnt sure if when I took the shock out, if the springs would need to come off when removing the top mount.
Have had a search to no avail :star:
yup 172/182 no compressors required. Other models however I would suggest unless you want a spring embedded in your face buy a set and use them when swapping springs.
