Now this isnt your regualr dash squeeking that you usually associate with Clios.
It sounds like its the fan belt slipping, it does it when i move off, and when i change ger up to 4th, if i quickley press on the accelerator, i mean right to the floor, it does i,b ut less so. Doesnt seem to get worse if i pull off quickley or slowley, and it only does it say 3 times outa 5.
BUT....
It seems to be comming from the rear drivers side (near side or offside, i loose track whihc is which) wheel. Have checks this and the wheel isnt rubbing or anything, when i pussh down - working the suspension its ok.
Any ideas guys / gals?
*edit: Its a 1.2 mk1 clio, Ph2
