STARCHIP ADVICE! PLEASE LOOK
  clio williams, Ph1 172
Right had my ECU out today to get some details off it. Numbers etc. Does anyone know if this chip should be correct? Here are the details from the chip:
SC0186 WSP50396
R19NMO1 WEB
23/04/1996 RN
heres the details off the bottom of the ECU:
Siemens ECU
HOM7700851741
BVM
7700857528
S101262105C
ON THE BARCODE IT SAYS: 000283420142850/92331
42/61
The standard chip inside the ECU says this on it:
FENIX 3A
785323
Come on someone must know if this is correct chp for my car??
All I know about this is that the code for the ECU is S101262105C this is the only relevant code. Maybe call Starchip and find out if it is compatible with the chip. As for fitting it, you need to be pretty handy with solder.
Anyone else got any views on this? Gonna have it fitted tuesday so please tell me any info before then! Cheers
