Steering column lock issue.
Matt Cup
  Iceberg 172 Cup
Swapped my steering wheel over today and I noticed that the steering column lock doesn’t engage? Now I have doubts if it’s ever worked or if me taking the original wheel off has disrupted something relating to the lock.
Has anyone else had similar issues?
Matt Cup
  Iceberg 172 Cup
Yeah neither did I so probably just a coincidence.
However I wonder how I can fix my issue?
Brigsy
  T.Turbo
Fairly common for it not working, mine does not work on my blue dci. New barrel to sort, wouldnt bother personally.
Brigsy
  T.Turbo
Wont be a fail as separate immobiliser, mot manual says
7.3. Anti-theft device
You only need to inspect the anti-theft device on M1 vehicles first used on or after 1 September 2001 with a steering lock as an anti-theft device fitted as original equipment.
It’s acceptable for a steering lock to be missing or not working as long as the vehicle has an engine immobiliser, or a permanently installed immobilisation device which acts on either the steering, brakes or the transmission.
Some electronic steering locks, generally on vehicles with keyless ignition systems, will only activate when the driver’s door is opened or closed.
If it’s not practical to check if a steering lock is working, you should give the benefit of the doubt.
