1.6 Ford Focus
There's a small issue with the driver and passenger doors on my Ph1 that the doors swing open fully... You wouldn't have thought it was a big problem but the passenger door has no catch in the middle that holds it half open so that door swings wide open if you let it go and I just had a mishap on my front drive that the driver side door is so stiff that I thought it was on the mid way catch part so I let it go and it swung wide open and hit the corner of the wall... Luckily it didn't hit it too hard and it onlt hit the door handle so no damage done.
Is there some way to fix this? Could it just be a bolt too tight or loose or would a bit of WD40 fix the stiffness?
