Renault Clio 182
Hello
How much boost can stock internals 182 engine hold?
230/240Hello
230/240
Ooft that'll be a flyer!230/240 psi
i think you mean bhp230/240
9psi.i think you mean bhp
I need to know if it can hold 0.5 0.6 bar boost safely??
great, so i’m having safe 0.5 (7 psi)9psi.
9psi.
The turbo is the smallest stock turbo for Subaru ImprezaDepends on the size of your turbo. But 7 to 10psi is considered safe (when mapped to suit) on a 172 engine with a t25.
Most engines are old worn and knackered, something will break.
Td04? Or tf035? As long as you have bigger injectors and a map it should be fineThe turbo is the smallest stock turbo for Subaru Impreza
And the engine was rebuilt by February 2023 so everything is hopefully good
TD04 it’s mapped and the afr is goodTd04? Or tf035? As long as you have bigger injectors and a map it should be fine
