Stupid heat shield question
  Clio 172
I'm sick of my rattling heat shield , hae tried to fix them but they are stupid ! Lol ... Can I just take them off , if so does it make much difference ?
thanks
  FF Clio 182
If it's close to the engine then I would leave it on. If it's the one by the back box I personally would rip it off
  Clio 172
Well you don't need a lot of stuff that they put on a car to be honest , they are a pain in the arse , the metal is wafer thin so that it will rust ..... Just. Wondered If it's worth messing around with or just remove all together
  Clio 172
It's the centre section part that's next to the back box one ... The fixing points are goosed so it will always rattle
danward
  TTS
I took mine off quite a while ago (the large rear section) as the rattle was driving me nuts. I hope it's not dangerous to drive without it!!
  182 ff
I solved mine rattling by putting plastic washers under each bolt.and pulling a bigger metal washer on the ones that has rushed through the heat shield.. it did get on my nervous when you revved the engine.
