Super pass for the DS
seb
  Clio trophy
i don'tknow either myself Yin but it lookslike some sort of device to run your own programs on the DS?
clicky
  Clio 197
It's a "passme" device/ROM.
Say, for example, you want to run Nintendo DS Software off a GBA cart storage device... you need a "passme" device.
What it does, is tells the NDS to boot up an ".nds" file from the GBA cart storage device, as opposed to the main ROM slot. So, it's like a boot disc relly.
The "max media launcher" is actually a "passme" device too.
There are many "passme" devices out there, along with many GBA cart storage solutions (GBAMP, Supercard etc... etc...)
Not all "passme" cards work with all GBA cart sstorage devices...
...furthermore, not all software is compatible with all GBA cart storage devices.
For that reason, I have created this thread, which tells you what to buy, and where from. It all works together nicely:
http://www.cliosport.net/forum/showthread.php?t=169945
As an alternative to a "passme" device, you can flash the firmware on your DS so that it boots .nds files.
In order to load the firmware update, you'll need a "passme" device, so you might as well not bother (particularly when there are dodgy firmware releases out there that will render your DS useless).
I personally did sucessfully flash my firmware, so that I no longer have that annoying health & safety warning on startup. A bonus is that I no longer need my "passme" device to run my software.
  Astra CDTI SRI
I have this setup for my ds.
http://www.divineo.co.uk/cgi-bin/div-uk/ds-m3mini
Works a treat. All you need is an SD card and some roms.
The passcard goes in the top where the normal games go and the m3 adaptor goes in the bottom, where the GBA games would normaly fit.
Download a rom, load it onto the SD card via the software that you get with the m3, stick the sd card into the m3 adaptor, the passcard into the top and turn the ds on.
Select the rom and play.
Easy as that!
I have about 600 games for my ds!
Check out http://www.ds-scene.net/
The guys there are very helpful and the forums are good.
  BMW e46 320 Ci Sport
it's awesome, i've used it and it works great, i use passkey though i think
