Suspension problem
  PH1 WANTED
I walked away from the Car this morning and had a casual look back at it as you do and noticed that the passenger front wheel looks like it's sticking out considerably more than the drivers side. Also the camber on the wheel is going the complete other way? The wheel almost looks like it's further out at the top than the bottom.
Why would this be or what could have caused this. The drivers side is fine camber looks fine and the wheel is sitting much better in the arch.
I have k-tec coilovers fitted.
  Black Clio GT
loose bolts, track rod ends not done up poperly or complete lack of setting up the camber/tracking properly??!!
  PH1 WANTED
Yeah I'm worried something is done up properly and has come loose. I've noticed my steering wheel isn't sitting straight either and it's it pulling that way.
ForceIndia
  Gentlemans spec 200
Bearing? Either way, I'd try not to drive it before getting it checked over.
ForceIndia
  Gentlemans spec 200
Naiths rear wheel did the same when the bearing collapsed. Very quickly became undriveable.
  PH1 WANTED
Problem sorted this morning. Camber bolt had come loose. Notsure this is that common though. Fingerscrossed it does happen again.
