Im swapping over an old 20gig hardrive for a 250gig drive in my parents couple of year old pc.
I took the old one out, plugged in the new one, booted up, went into bios, "found" the new harddrive, Set first boot to CDROM, inserted winxp cd, saved and exited bios, after a few secs I was in DOS and asked if I wanted to boot from CD?.. I wasn’t able to answer this as if the keyboard didn’t work (it does work i delete keyed into bios), then an error appeared…. I cant exactly remember it as im at work but was something about "drive error" or "cannot read drive" etc…. I could do anything to retry, quit or anything.. Had to push reset key
I think it could be one of the following probs:
- The cd could be dodgy. I remember having probs with it on my last build.. BUT when I tested it on my system it read the cd fine within winxp/explorer…
- Could it be harddrive data cable??.. Do you think I may have been using a 40wire cable and now MUST use an 80 for the 250gig drive??
- Is the error reffering to the cv "Drive" or my hard"drive"?
- Probably be a good idea testing the new harddrive as a slave on MY pc wouldn’t it I guess
After not getting anywhere I put the 20gig back in, booted up and all fine… will work on it again tomorrow night..
Any clues chaps?
Any clues chaps?
