Darren S
Chaps,
I've had some tearing in onscreen graphics with the two GTX460's - but only in a few games. Of the ones I've played over the last fews days since getting the SLi bridge, just Skyrim and Company of Heroes of shown tearing. BF3, Shogun 2 and everything else have been fine.
My gfx card spacing is currently at 90mm between them and they are connected by a 100mm SLi flexible cable. Having looked into it on the internet, some people suggested that if the cable ribbon 'bows out' away from the cards, this can either move one connector slightly to stop it forming a proper connection on the card - or the ribbon pushes itself away from the connector pins on the connector - and a similar issue occurs.
Taking that onboard, I shut down the PC, and applied a little pressure onto the SLi cable so that it bowed-in and the ribbon curved inbetween the two GTX460s. Fired up the PC and both Skyrim and CoH and received perfectly smooth graphics. I even played a 90min round of CoH afterwards without a single glitch.
Clearly the Asus SLi bridge I have here is a little flakey at best. I'm now on the hunt for a rigid 90mm SLi connector like this...
http://www.ebay.co.uk/itm/NEW-NVidi...359131&po=LVI&ps=63&clkid=4139869550501193949
....but ideally I'd like to get one from somewhere in the UK, if anyone knows of a place?
Alternatively, I have the 3-way SLi bridge that came with my mobo, that I will never use. As both of the GTX460's only have one SLi connector on them and not two, could I actually saw down the middle of the 3-way SLi bridge?! A bit extreme, I know, but if it works - hey - why not?
Cheers guys...
D.
Cheers guys...
D.
